To what do the A and B measurements refer?
Greetings to all. It would be very helpful if someone would explain what the "A" and "B" measurements refer to. Thanks. Chuck
Re: To what do the A and B measurements refer?
Merci beaucoup.
Also, what bearings should be used that are thin enough to work with 5mm aluminum? The closest I can come to 5mm aluminum sheet is 0.190 inches (5mm=0.196") The next size larger sheet available is 0.250" or about 6.6mm.
Charlie
Charlie
Thank you. That is very helpful.
