Je pose ces quelques questions de la part de Steve, de Nouvelle Zeland, qui construit un CP750. J'espère qu'il recevra beaucoup de réponses
I'm posting theses questions for Steve, from New Zeland. I hope he will receive many answers
Bonjour from New Zealand.
Sorry I do not speak/write in French so I hope you are able to translate this below.
I am building a CP 750. I started some time ago and have completed the steel tube fuselage. I have not worked on it for some years but am now thinking of finishing the project.
I have just recently found the Avions Piel web site and have enjoyed the photos and forums (when in English).
I have a number of questions you may be able to help with.
I have previously detected the interference with the rear control mechanism and the fuselage tubes and have a modification in mind.
I have been fortunate to see several Beryls in USA and speak with the builders. They all say (including some American articles on the beryl) that the wing incident is too great as shown on the plans. 4 deg 30
I note the CAP 10 appears to have 0 deg. And no wash out.
Has this ever been modified on the plans?
What are the 180 hp Berlys using?
If the incidence is changed have there been changes made to the U/C leg angles, engine thrust line (down and to side) and what if any is the tail plan incidence.
I have assumed that the datum is the top tube.
I see that there is a CP751 design. What are the changes over the 750 (plans I have) for the lager hp. My plans came from Canada in mid 1990’s
Are there any details on the seat positions? What have other used?
I found on one of your forums some plans for CAP 10.
Were they every released to amateur builders as I would be interested to know what difference there are in the wing structure and spar.
I will try and send some photos soon.
Look forward to your reply and kind regards.
Steve Gwilliam, New Zealand.
