-the plywood sheet for the webs in tailplane spar is one piece entirely each side ,or could be in 2 sections of plywood as the ply in the main spar for example ????
-the cap/semelle of the spar is in one piece ???
tanks
I think the webing can be in two pieces as long as you make the correct scarf joint between the two pieces of plywood.miguel ramos a écrit :Hi Im building the tailplane ribs. and spar
tanks
