Nous sommes le Mar 19 Jan, 2021 4:44 pm
Poster un nouveau sujet Répondre au sujet  [ 2 messages ]
Auteur Message
 Sujet du message: angle dièdre du longeron arrière
MessagePosté: Mer 15 Avr, 2020 11:53 pm
Hors ligne
(I was going to delete the following but am unable to do so. I laid out the dimensions using the dihedral from the main spar and there is very little difference and that is only in the area between the fuselage attach points. So, all is well.)
Greetings and hope all are well. We are sheltering in place and it is good to be building a beautiful airplane at such a time.
Because of concerns over wood quality, I have decided to re-make the rear spar. I don't recall how I made the first one and am concerned because I do not see any way to determine the exact dihedral angle on the plans. It appears that the best way is to use the same angle as the main spar. Is this correct? Thank you.
I have started to build the new one on top of the old but would like to verify that it is correct before proceeding further. Thanks.
Charlie
Charles Hinton
Haut
 Profil Envoyer un e-mail
 Sujet du message: Re: angle dièdre du longeron arrière
MessagePosté: Mar 21 Avr, 2020 11:29 am
Hors ligne
Bonjour Charlie,
The best will be to take the same angle of the "longeron".
You only have to report the angle direct on the table.
best regards
Jean-Philippe
Haut
Qui est en ligne
Rechercher:
Aller à:
cron
Traduction par: phpBB-fr.com
phpBB SEO
